Print at Oct 5, 2026, 12:03:09 AM
Posted by Keet at Jul 9, 2023, 8:48:21 AM
Re: Create room from walls
Hans is correct with the mouse handling but from what I understand from your post you are just using the walls to create a room for outdoor areas. "Odd shapes" I presume to be with very low curved walls which afterwards are either removed or remain as a thin low border.
A weird fact is that when you curve parts of a wall they sometimes 'break' in the sense that they no longer enclose the area you want to fill with a room. I've done this numerous times when creating curved walking paths through a very large outside area with 0,1 thick walls. Since the walls aren't really used as walls but merely as a border you can cheat and overlap the wall ends to ensure the area is closed.
A trick to find connections that are broken: draw a box of walls around a connection point and double-click for a room inside. If the whole square fills the connection is broken, if the connection is solid only one side will fill. Move the square to the next connection and repeat.
