Print at Oct 10, 2026, 11:00:09 AM
Posted by hansmex at May 10, 2010, 7:16:10 AM
Re: Window shapes
Vaughan:
If you check the List Attachments you will find there a series of transparent boxes. If you check the OBJ en MTL files with a text editor, you will see how the transparency works.
From the 3D Models section you can download a cylinder or triangle, which you can then give the desired transparency. You will probably have to rotate the model while importing it, so that its orientation matches your needs.
With these new glass objects you can start building your special windows. For this you can use a program like Blender, Misfit 3D or Art of Illusion.
