Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Sep 23, 2026, 10:36:43 AM |
| Posted by 241177793 at Jul 16, 2023, 4:59:15 AM |
Re: Wirings plugin Greetings Daniels118, I have installed the PAN3D plug-in and Wiring plug-in with my Sweet Home 3D software. The problem is when I'm drawing a wire on walls, the vertical lines didn't count on distance (length) and the horizontal is right. https://ibb.co/w69S07y https://ibb.co/k627qhg https://ibb.co/k1PD9DC The images shows the horizontal wire is 38cm and vertical wire is 0cm with 40cm x 40cm tiles setting on walls, those facts test with SH3D7.1(OpenJDK 11 and ORA JDK1.8, PAN3D3.7.5, Wiring 4.2), SH3D6.6(OpenJDK 11, PAN3D1.7, Wiring 1.7) on different laptop (Windows 7, Windows 10) and none of those could calculate the vertical distance (length) right. Then I've opened the sh3d file with txt and find the wiring xml tag, the inner coordinates only have X and Y, not with the Z dimension on it. https://ibb.co/dGyrJ3V What's wrong with my installation? |
Current timezone is GMT Sep 23, 2026, 10:36:43 AM |
