Print at Oct 4, 2026, 8:36:16 PM
Posted by Keet at Jul 16, 2023, 9:33:18 PM
Re: Stairs U shaped two landings
It can always be fixed but not with the staircases as you have generated. Unless of course you can make the top staircase smaller to fit the landing off the bottom staircase but that is probably not what you want.
The best solution is to generate just the three staircases without landings and then use boxes to create the landings.
