Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Stairs U shaped two landings » » » » Post: Re: Stairs U shaped two landings |
Print at Oct 4, 2026, 5:19:59 AM |
| Posted by Keet at Jul 18, 2023, 7:19:08 AM |
Re: Stairs U shaped two landings The walls you can split and adjust in height. For the cutout in the floor you will have to add your staircase to a Furniture Library. In the Furniture Library you can customize the cutout in the floor. The cutout is defined as an SVG path and you can download a pdf here that explains how that works. It looks difficult but once you understand how to draw a path it's simple. To create your own Furniture Library you need to download and install the Furniture Library Editor . ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 4, 2026, 5:19:59 AM |
