Print at Sep 30, 2026, 3:36:23 AM
Posted by Keet at Jul 19, 2023, 8:32:21 AM
Re: Skillion roof design
I'm not sure but from what I see I suspect the roofs are boxes resized and tilted. You can see that because of the square angles of the borders. Even if they are something else you can achieve the same with boxes.
If you want to have the border with vertical sides you can use the Generate 3D Shape (menu Tools) to create that shape. First create the roof with a box and tilt it to the correct position. Export and import the box-roof so you have some guidance to the dimensions you need for the shape.
