Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: transparent models from walls in YafaRay, rendering fails » » » » Post: Re: transparent models from walls in YafaRay, rendering fails |
Print at Sep 30, 2026, 11:43:15 AM |
| Posted by Keet at Jul 28, 2023, 2:31:55 PM |
Re: transparent models from walls in YafaRay, rendering fails Check your mtl file for the wall. You can try these basic glass definitions in the .mtl file: newmtl Glassnewmtl GlassKa is the ambient color (R G B), i.e. the color you want you curtain to have. You can of course keep the color you already have for Ka. Kd is the diffuse reflect color (R G B) In Sweet Home 3D the same as Ka but you can try a different color. illum is the illumination model. illum 1 is the default and represents a flat model. Note that the first example doesn't have a line with Ks because the illum 1 model doesn't use specular highlights. If there's a Ks line it is ignored. illum 2 requires the Ks line to define the specular highlights: R G B color for the highlights. Ns is the shininess factor Ni is the optical density, i.e. the light breaking refraction. For normal window glass this ia 1.45 ~ 1.5. For your curtain you may want a different value although it's often hard to see a difference. Keep values within the range 0.001 to 10. d is the transparency (0.0 ~ 1.0) 70% transparent = 0.3 (1.0 = 100% opaque, the default) The problem might be based because of the usage of a wall. To get the wave pattern the wall has multiple sections and each section has sides that show through. Try a clear glass curtain and you will see that every section end shows through the glass. You can remove those ends in Blender but it is quite a job. Last, try the difference between a color and a texture. You might find that the texture is the problem and not the wall. Experiment with different values because I suspect there's a difference between SunFlow and YafaRay in how they handle the material definitions during rendering. I'm not sure if Sweet Home 3D shows the specular highlights but the photo renderer should. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 30, 2026, 11:43:15 AM |
