Print at Sep 23, 2026, 11:54:56 AM
Posted by Tungmeister at Jul 29, 2023, 9:34:43 AM
Re: Staircase generator plug-in
I might provide a longer list of materials in a coming version since some of you think it's really necessary. I'll update the translation at that moment.
Could you share how to set randomized coordinates for the textures as you did for the threads and risers?
Source code is included in the plug-in so you can have a look by yourself. It's just a random offset added to x and y texture coordinates, a different offset being drawn for each tread and riser...
Could you help me remove the random values please? My stairs have a stair runner on them so I need the texture to be uniform across all the steps. I downloaded the source and replaced the random values with 0s however after compiling and adding the plugin sweethome just hangs on the splash screen and I can't work out what I'm doing wrong.
