Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: 3D dimension lines plugin » » » » Post: Re: 3D dimension lines plugin |
Print at Sep 23, 2026, 10:36:50 AM |
| Posted by IvanDiaz at Aug 1, 2023, 9:32:42 PM |
Re: 3D dimension lines plugin Good morning Daniels118, I have recently started using plugins and I ran into a couple of problems using your plugin. The first problem has to do when I generate an ordinary measurement in any part of the house, that is, I generate a line that measures 100cm and I double left click to fix the line in place, but the problem arises when I accidentally double left click while near or above the previously generated line. And what happens is that the number zero appears and it no longer generates more measurements, regardless of which part of the house you click on, the number zero will always appear. The second problem appears as a consequence of the first problem, all the objects in the house I can move freely in the 2d plane, but in the 3d plane they appear in the same place as if it were some kind of bug in the system. And one more thing, how do I delete a measurement line? I have only been able to delete a wrong line by clicking the undo button, but I don't know if there is another way to do it. ________________________________________________________ If anyone who manages this forum sees this message, I'm letting you know that you can't log in from Microsoft Edge, with the Chrome browser I had no problem logging in. |
Current timezone is GMT Sep 23, 2026, 10:36:50 AM |
