Print at Sep 27, 2026, 4:57:43 AM
Posted by osopez at Aug 6, 2023, 5:59:24 PM
Re: Error opening Sweet Home 3D
Hello ,
In case it helps someone else, I managed to solve it with the following from the French forum:
http://www.sweethome3d.com/fr/faq.jsp#disable3D
Translated into English, it says the following:
"- How do I turn off all features of Sweet Home 3D using 3D?
Since version 3.2, when running Sweet Home 3D, you can disable all features that require the 3D features of the computer. Then you get the Sweet Home 2D app that works without a 3D view, without a 3D View menu, without the ability to create photo or video renditions, and without the ability to import furniture individually; but drawing on the 2D plane is fully functional there, SH3D files created with this version are compatible with those of Sweet Home 3D and it is still possible to import furniture libraries.
To install and run Sweet Home 2D with Java Web Start, please install Java and click this link (http://www.sweethome3d.com/SweetHome2D.jnlp), Sweet Home 3D and Sweet Home 2D can coexist on the same computer if it is necessary. You can also launch Sweet Home 2D by downloading the executable (http://sourceforge.net/projects/sweethome3d/f...etHome3D-7.1.jar/download) Jar version of Sweet Home 3D and then running the command:
java -Dcom.eteks.sweethome3d.no3D=true -jar "C:\Users\WindowsUser\Desktop\SweetHome3D-7.1.jar"
All the best
Buenas,
Por si a alguien más le sirve, conseguí solucionarlo con lo siguiente del foro en Francés:
Traducido al castellano, dice lo siguiente:
"- ¿Cómo desactivo todas las funciones de Sweet Home 3D usando 3D?
Desde la versión 3.2, al ejecutar Sweet Home 3D, puedes desactivar todas las funciones que requieren las características 3D de la computadora. Luego obtiene la aplicación Sweet Home 2D que funciona sin una vista 3D, sin un menú Vista 3D , sin la posibilidad de crear representaciones de fotos o videos, y sin la capacidad de importar muebles individualmente; pero el dibujo en el plano 2D es completamente funcional allí, los archivos SH3D creados con esta versión son compatibles con los de Sweet Home 3D y aún es posible importar bibliotecas de muebles .
Para instalar y ejecutar Sweet Home 2D con Java Web Start, instale Java y haga clic en este enlace (http://www.sweethome3d.com/SweetHome2D.jnlp) , Sweet Home 3D y Sweet Home 2D pueden coexistir en la misma computadora si es necesario. También puede iniciar Sweet Home 2D descargando la versión Jar ejecutable (http://sourceforge.net/projects/sweethome3d/f...etHome3D-7.1.jar/download) de Sweet Home 3D y luego ejecutando el comando:
java -Dcom.eteks.sweethome3d.no3D=true -jar "C:\Users\UsuarioWindows\Desktop\SweetHome3D-7.1.jar"
Un saludo
