Print at Oct 3, 2026, 7:33:52 AM
Posted by Keet at Aug 7, 2023, 1:20:05 PM
Create a room between rooms
I would like to have the option to create a room between rooms.
Currently you can create a room with a double-click inside enclosed walls but when you are drawing rooms for the Terrain Generator you don't want walls but you want rooms that connect seamless to each other. For straight lines that's easy to do manually but for a terrain you want to use curves for rivers and paths.
The idea is that you can draw thick walls for a river or path and with the double-click create rooms on each side of the wall. Then you want to remove the walls and fill in the open space with a new room as the river or path. When the river/path is a room you can elevate it along with the terrain on each side using the Terrain Generator.
In short this means that a double-click to create a room not only looks for wall boundaries but also for adjacent room boundaries. That way you can create a room in a blank space that is partly enclosed by walls and partly by rooms. The seamless connection ensures that there is no gap between rooms which you would have with temporary thin walls.
