Print at Oct 4, 2026, 7:16:15 PM
Posted by hansmex at Aug 8, 2023, 6:03:27 AM
Re: Create a room between rooms
I see your point, but using thin walls (0,1 mm) gives gaps that are not (or hardly) noticeable in the end result.
Moreover, using walls you can make curved "lines", which you can't if using only rooms, as far as I know.
