Print at Sep 23, 2026, 11:54:25 AM
Posted by Puybaret at Aug 9, 2023, 10:13:23 AM
Re: Sweet Home 3D 7.2
Thanks for your first feedbacks smile
The orange, horizontal dimension has the lines displayed at the bottom of the room and the digits at the top of the room.
This dimension seems to be elevated since its left point is at half height of the wall. But texts are too far. Strange... I never encountered this issue. Could you send me you file (or a simplified version) so I can check on my side?
I feel that the Dimensions dialogue is easier to understand if start and end point coordinates are diplayed directly after each other (as in walls, furniture, etc.). The elevation comes directly after the coordinates.
Sorry, but I tend to disagree. Elevation is part of 3D coordinates and it's relative to Start point section in the dialog box.
3D VIEW TOGGLE
When I shift-click nothing happens?
It's probably because you didn't remove Pan3dView plug-in, did you?
RECOMPUTE ROOMS (super-super feature!!)
I would love to see this option also in the Modify Rooms dialogue.
It's not possible to have this feature in room modification dialog box or in Plan menu because it needs a reference point to work. It's the reason why it didn't appear yet in Sweet Home 3D until... I had the idea to program it in the contextual menu which can use the point where you right click as a reference point.
