Print at Sep 23, 2026, 11:54:41 AM
Posted by Keet at Aug 12, 2023, 7:46:57 AM
Re: Furniture Library Editor released
As far as I'm concerned, I would like to be able to add a unmodifiable property because my lights use the description property so that they are recognized by the photo plug-in.
Starting with 7.2 you can!
From the announcement topic of 7.2 beta :
It's possible to define additional furniture properties to handle customized user data associated to the objects added to your home.
As the value of additional properties set in a furniture library will be copied to a new home object when it's added to the plan from version 7.2, you may give the initial value of these properties in a SH3F file.
You can create a custom property and you can set this property to unmodifyable. The description property can return to it's original purpose. A custom property can't be defined with a UI yet but it can be set from a plug-in. Check it out. It will solve your problem in a much better way than using the description field.
