Print at Sep 23, 2026, 12:35:12 PM
Posted by Keet at Aug 15, 2023, 4:52:21 PM
Re: Furniture Library Editor released
- If present, the trailing digit of an imported model file isn't removed anymore (the reason why I introduced this was to avoid showing these numbers when a user imports similar models).
Great! That's one I keep stumbling into when adding multiple objects in a series. I had to manually add the correct numbers to each one after import but that is now over. Thank you!
