Print at Oct 2, 2026, 2:24:30 AM
Posted by LaVache at Aug 17, 2023, 8:32:25 AM
Rules é markers, select points, fraction of units, angles…
Hi, I'm new here and this is my first message.
I'm new also with Sweet Home 3D. It is already nice but… In the past I was experimented with Adobe Illustrator so I would like to find some improvements in SHD3 :
    1 To be able to define units & pitch of the rules with millimetre's fraction and to be able to drag vertical and horizontal guidelines from it. I was used to use 1/68000 in AI… It would be nice without to go that far, 1/100 would already be terrific.
    2 For previous purpose it would be fine to define a center of rotation anywhere then to have fractions of degrees.
    3 Then I would like to be able to select & edit points of an object were I would need it, like corners of a furniture.
    4 Last but not least, to be able to define ends of walls like with lines from Illustrator (square that overflows or stops sharply, acute angle, rounded...)
    5 B-spline curves and corners… blushing
    6 Sides as editable map not as picture. silly
biggrin
