Print at Oct 2, 2026, 9:38:20 PM
Posted by Keet at Aug 19, 2023, 8:34:58 AM
Re: Copy / Paste Between Files
Yep, that works too.
You can also import furniture by dragging an .obj file from the file manager in the 2D window. You can even select and drag multiple .obj files and it will open the import furniture dialog for each object, one after the other. If furniture isn't added from the furniture list I always import it like that because it will import at the position where you drop it.
