Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Imported backround and problems with levels » » » » Post: Imported backround and problems with levels |
Print at Sep 26, 2026, 1:34:07 AM |
| Posted by Egretta at Aug 25, 2023, 10:21:54 AM |
Imported backround and problems with levels Hi, please do you know where is the problem? I imported the scan of the real plan ground floor and built the wals. In the first floor I can also move with the wals from the ground floor and it is wrong. I can“t cath the walls from the first floor properly, they mix together with the ground walls. When i did floors withhout the imported backround of the plan, its ok. In every floor I can move only with the walls, which are built on the concrete level. Thank you for any idea! |
Current timezone is GMT Sep 26, 2026, 1:34:07 AM |
