Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Imported backround and problems with levels » » » » Post: Re: Imported backround and problems with levels |
Print at Sep 25, 2026, 10:12:54 PM |
| Posted by Keet at Aug 26, 2023, 6:08:33 PM |
Re: Imported backround and problems with levels The problem is most likely incorrect wall/level heights. Set the level height of level 0 to the same height as your walls on level 0 (right click on the level tab to edit level properties). Check the floor thickness you have on level 1. Level 1 elevation must start at the height of level 0 + the floor thickness. Example: level 0: walls 250 high, set level height 250 level 1: walls 250 high and floor thickness 20: level 1 elevation 250+20=270, level height 250. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 25, 2026, 10:12:54 PM |
