Sweet Home 3D Forum » List all forums » » Forum: Forum en français » » » Thread: Modifier un modèle de porte ? » » » » Post: Re: Modifier un modèle de porte ? |
Print at Oct 2, 2026, 5:38:56 AM |
| Posted by Keet at Aug 29, 2023, 7:08:54 PM |
Re: Modifier un modèle de porte ? Use a plain text editor that can do a replace_all. Most editors can do that. Export the sill object to sill1.obj. Open the file and replace_all "g " with "g sweethome3d_rail_1_". Save and copy the file to sill2.obj, sill3.obj, etc. Edit sill2.obj and replace_all "sweethome3d_rail_1_" with "sweethome3d_rail_2_". Same for 3-9. Use the same technique for the 9 doors: export a single door to door1.obj. Edit and replace_all "g " with "g sweethome3d_opening_on_rail_1_". Save and copy to door2.obj, door3.obj, etc. Edit each one and replace with the correct number. Still a lot of work but at least you can see what you are doing. Import the 18 objects to merge with the outer frame. Using the object names you can place the correct sill under the same numbered door. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 5:38:56 AM |
