Print at Sep 24, 2026, 10:01:54 AM
Posted by Keet at Aug 30, 2023, 4:05:35 PM
Re: Generate roof plugin
A quick look shows several inconsistencies:
Check you preference settings for new levels because the Roof Generator generates a level 'Roof-gen' with elevation 365. If you have that set in your preferences (wall-height+floor-thickness=365) than that is the cause. (Dorin can determine if it's because you have a level height of 1 on level 0 that could cause the Roof Generator to use a default.)
Your level 0 is 1 high, should be 300 with walls 300 high.
Change the Roof-gen level elevation to 300 and the probem is fixed. (double click on the level tab.)
@Hans: good find, I missed the different wall heights.
