Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Apartment project with lighting by invisible hemispheres. I continue advertising » » » » Post: Apartment project with lighting by invisible hemispheres. I continue advertising |
Print at Sep 30, 2026, 4:51:10 AM |
| Posted by GaudiGalopin3324 at Sep 1, 2023, 6:13:00 PM |
Apartment project with lighting by invisible hemispheres. I continue advertisingHi. I continue to try to demonstrate the advantages of this light system in the room. There is nothing complicated in it, but the result is very different from the usual scheme (using balls). The entire area of the room is filled with invisible hemispheres of different colors. At the window it is blue, white in the center of the room, yellow in the back of the room. By changing the power of the hemispheres (from 2% to 6%), it is possible to realistically transmit daylight from the street together with the warmer light of interior lamps. The organza curtains are made by a model from the walls. This is an OBJ model with 80% transparency, the texture is opaque white. This is a real project, I will add other angles of the premises in this topic as I develop. The main thing is that I will do lighting everywhere using Invisible Inward light half sphere ![]() |
Current timezone is GMT Sep 30, 2026, 4:51:10 AM |
