Print at Sep 23, 2026, 4:26:57 PM
Posted by Keet at Sep 5, 2023, 8:05:15 AM
Re: Sweet Home 3D 7.2
I think what dorin wants to express is that an object doesn't remain in it's (vertical/Z) position when a deformation changes it's height. So no problem with the door because it stays the same height but the elevation of the velux window changes when opened. The non-deforming part of the window should remain at it's original position.
From what I can see on the images the deformed furniture has it's bottom at the same elevation as the non-deformed was, which is not correct.
