Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 7.2 » » » » Post: Re: Sweet Home 3D 7.2 |
Print at Sep 23, 2026, 1:09:49 PM |
| Posted by dorin at Sep 5, 2023, 5:32:03 PM |
Re: Sweet Home 3D 7.2 @Keet You have partially right. So no problem with the door because it stays the same height Indeed but at different X and Y. If you look closely to my first two picture you could see I've arranged the doors at same Y and the corresponding X. After I open the door (Thanks God wasn't a Window ) the bounding box has been modified and of course the X and Y BUT,somewhere in the code Emmanuel compute the necessarily corrections so the door frame appear to stay in their position and only the door has been moved. I need this correction to be made also for Z. I've tried to find the responsible part of code but maybe I've don't try hard enough. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 1:09:49 PM |
