Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Categories » » » » Post: Re: Categories |
Print at Oct 4, 2026, 5:17:27 AM |
| Posted by Keet at Sep 7, 2023, 4:10:14 PM |
Re: Categories Opening from Sweet Home 3D requires that it knows which library and where the library is located, which is NOT the default Sweet Home 3D library directory if you do it right. Maybe that is why you have the crashes. Do you edit a library in the Sweet Home 3D library directory? Maybe even when Sweet Home 3D is open? If you do, than change your work flow. Edit the library in a different location and after saving import from that location. The library importer will copy it to the Sweet Home 3D library directory. Editing in a different location has the advantage that you can keep Sweet Home 3D open while editing the library. It also provides a location for all your libraries, even those not imported. I like the editors as separate tools. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 4, 2026, 5:17:27 AM |
