Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Rotate plan plug-in » » » » Post: Re: Rotate plan plug-in |
Print at Oct 4, 2026, 10:08:39 AM |
| Posted by dorin at Sep 10, 2023, 6:40:34 PM |
Re: Rotate plan plug-in For my personal use I've updated the plugin with the polylines rotation. It was not a big deal. I still have a problem with the background image rotation, but I will (probably) fix it. or to see the BEFORE/AFTER on the same project. To toggle from visible to invisible multiple items I use multiple levels at same elevation with different furniture in it and toggle the level visibility. Only to see the home from different positions you don't need to rotate the hole home. Move the visitor and store the point of view. If you need a specific orientation of building you don't need to rotate the hole home. Rotate only the compass to indicate the correct orientation. @Keet How this plugin works on your side? I'm interested about background image. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 4, 2026, 10:08:39 AM |
