Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 7.2 » » » » Post: Re: Sweet Home 3D 7.2 |
Print at Sep 23, 2026, 11:54:44 AM |
| Posted by dorin at Sep 13, 2023, 12:38:34 PM |
Re: Sweet Home 3D 7.2 you move a window part lower than the bottom of the window, a position which has no meaning. 1. Correct, but what if it is a pocket window? 2. If you use a roof part with a window already inserted (from a wall) will be also no problem. 3. If you make a hole in the roof and insert manually a closed turn window (like in this post ) you will have problems with the elevation every time you open the window. Anyway in the future release of RG-4.5 the holes and windows are automatically created and inserted on the roof in the correct position but I can't avoid future window elevation modifications. My workaround was to mentioned this in the future user manual of RG. Probably I will need to elaborate a little the operation for users: new elevation = old elevation - (new High - old High)/2 or something similarly with more screenshots. As you can see there it is solutions for everything ![]() ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 11:54:44 AM |
