Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Open GL error trying to launch » » » » Post: Re: Open GL error trying to launch |
Print at Oct 2, 2026, 2:57:19 PM |
| Posted by azuya at Sep 16, 2023, 9:22:39 PM |
Re: Open GL error trying to launch hi.. i´v just tried that fix that appear in faqs and.. works!!! thankyou very much!!! "If running Sweet Home 3D in 32 bit still doesn't work, download the file SweetHome3D.l4j.ini, copy it in Sweet Home 3D installation folder (by default, C:\Program Files\Sweet Home 3D or C:\Program Files (x86)\Sweet Home 3D) and relaunch Sweet Home 3D. The file SweetHome3D.l4j.ini tells Sweet Home 3D to use the DirectX version of the Java 3D library rather than the OpenGL version, but this option is available only in 32 bit (if you installed a JRE 32 bit, you may also click on this link to run Sweet Home 3D with Java Web Start and the DirectX version of the Java 3D library)." " |
Current timezone is GMT Oct 2, 2026, 2:57:19 PM |
