Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: "Black Screen" Running Sweet Home 3D on QEMU/KVM on AMD » » » » Post: Re: "Black Screen" Running Sweet Home 3D on QEMU/KVM on AMD |
Print at Oct 8, 2026, 10:35:44 AM |
| Posted by Keet at Oct 4, 2023, 8:23:49 AM |
Re: "Black Screen" Running Sweet Home 3D on QEMU/KVM on AMD 1. Remove your 6.6 Sweet Home 3D version. The version from the repository is way too old. Download and install the latest 7.2 version. 2. If you have not configured direct throughput of your graphics card to the virtual machine it's not AMD but a virtualized graphics card. 4. Use the SweetHome3D-Java3D_1_5_2 startup script instead of the default SweetHome3D script. (This alone will probably solve your problem with the 6.6 version too.) 3. Make sure your graphics driver is up-to-date if running from the host or with direct access to the graphics card enabled. 5. In my experience using Sweet Home 3D inside a virtual machine is slower than on the host. You'll experience this when projects get bigger. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 8, 2026, 10:35:44 AM |
