Print at Oct 3, 2026, 9:42:46 PM
Posted by Walter125 at Oct 13, 2023, 4:35:52 PM
Re: Making transparent the ceiling of a room, but opaque for sunlight ?
Thanks for the tip, I will try. Are you sure it works also for photo quality 3 and 4 ?
I tried with a special object, instead of the box, a plane with only two faces: the top and the bottom and a thickness of 0,1cm, making the bottom transparent but not the top. It doesn't seem to work.
I would like to disable the ceiling but keep it opaque to sunlight, in order to get an outside aerial photo of the inside of the house. With the same lighting as if the ceiling was here to stop the sunlight.
