Print at Sep 27, 2026, 8:00:18 PM
Posted by Keet at Oct 15, 2023, 4:35:19 PM
Re: Bug found in HomefurniturePanel.java
It does look like bug #1184. But I doubt it's a system update problem. I run into it every now and then on three different systems. Although all three are Debian (one host, two VM) they are different versions. The same problem persists on all three before and after system updates. Sometimes it helps to close Sweet Home 3D and restart it, other times I just keep on trying and after multiple tries it suddenly works.
It's as if the 3D view to display the model can't be painted. In rare cases just modifying a color and then trying the deformations works, as if the model wasn't fully loaded before and changing a color loaded it correctly for 3D display.
The main problem is that it isn't consistent, not even with the exact same model. This makes it very hard to determine what exactly is causing this. As far as I remember this happens with all versions of Sweet Home 3D, at least for the last 1-2 years.
