Print at Oct 4, 2026, 11:36:38 PM
Posted by jogibear9988 at Oct 26, 2023, 10:49:25 PM
Re: Webcomponent support in SweetHome3D JS
I now also remove the "define" calls from some additional libs. Cause I use "monaco" editor in my frontend, wich is using require/define and this does not work with the libs. In these the code is only for nodejs support, but I think it is not needed there.
Best would be to switch to es6...
see commit: https://github.com/node-projects/sweethome3d-...cbbfc5f6507a62f1a5cc97d57
