Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do I keep model from moving when using 'Modify openings...' for object with horizontal hinge? » » » » Post: How do I keep model from moving when using 'Modify openings...' for object with horizontal hinge? |
Print at Oct 5, 2026, 8:04:32 PM |
| Posted by mjbiggs at Oct 31, 2023, 4:38:53 PM |
How do I keep model from moving when using 'Modify openings...' for object with horizontal hinge? I've created a window model with a flap with rotates about a horizontal hinge. For an existing model with similar rotation see 'Folding wall seat' by Scopia. If the 'Folding wall seat', is attached to a wall, and then adjusted so that the seat rotates down, then the whole object is repositioned up the wall. It appears that SweetHome3d applies the object elevation to the lowest part of the object, and this of course changes each time the object opening is modified. Is there a way to prevent this vertical movement, akin to keeping a door static horizontally when it is opened? |
Current timezone is GMT Oct 5, 2026, 8:04:32 PM |
