Print at Oct 1, 2026, 1:14:32 AM
Posted by Keet at Nov 2, 2023, 6:36:29 PM
Re: This is a question and Wishlist all in one
merriam-webster.com:
catalog: as in list
a record of a series of items (as names or titles) usually arranged according to some system
The (Furniture) Catalog is the top left pane where all available furniture is listed, i.e. the furniture list. The Texture Catalog appears when you select Modify Furniture, Texture. It's the list of texture images from which you can select one to apply to your object.
If you don't see the top left pane (the furniture list) look at the top border of the left pane. You can drag down that top border and the pane should open. You can also use the tiny arrows on the border. The same goes if you don't have any panes on the left: drag the left border of the big pane to the right and your left panes should appear.
If this is what made you loose the panes you probably accidentally clicked one of those tiny arrows.
