Print at Oct 15, 2026, 10:50:53 AM
Posted by Puybaret at Nov 7, 2023, 4:41:45 PM
Re: How to create a 2D grid and contour map using the Terrain generator plugin
Here's another trick which consists of transforming the surface to grid lines in OBJ format:
- generate the terrain with the plug-in
- change its color to black (or any other color you want for the grid)
- export it to OBJ format, choosing Export selection option when prompted
- open the generated OBJ file with an editor able to handle regular expressions
- replace
f \d+//\d+ (\d+)//\d+ (\d+)//\d+
by
l $1 $2
- save the modified OBJ file
- import the modified OBJ file in Sweet Home 3D
Good luck!
Attachment TerrainGrid.sh3d (36382 bytes) (Download count: 747502)
