Print at Oct 3, 2026, 12:54:09 PM
Posted by hansmex at Nov 9, 2023, 8:15:52 AM
Re: Copy and paste method
Not sure if this is what you want...
1 - CTRL-A to select everything
2 - MODIFYY FURNITURE --> INVISIBLE to make all you furniture invisible
3 - if necessary repeat for every level
4 - you should now have an empty building
Instead of making your furniture invisible, you could delete it and save the empty model under a different name
Or you could create levels at the same height for every level and copy the furniture to these levels. making the level invisible, lets the furniture "dïsappear"
