Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Floor to ceiling columns » » » » Post: Re: Floor to ceiling columns |
Print at Oct 5, 2026, 2:38:17 PM |
| Posted by Keet at Nov 16, 2023, 12:17:45 PM |
Re: Floor to ceiling columns Is there a way to make Floor to ceiling columns I've been trying messing with the heights section for walls and no can do so far unless i am not doing it correctly but i believe there is no Floor to ceiling columns feature just yet Floor to ceiling columns are simply columns with the same height as the walls. Make sure your level height is the same as your wall height. Make columns with small squares of walls, a cylinder, or a box. You can also create custom columns by stacking other objects or download 3D column models. Just make sure their height is the same as the wall height and they should be floor to ceiling.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 5, 2026, 2:38:17 PM |
