Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Sep 23, 2026, 10:36:33 AM |
| Posted by Keet at Nov 16, 2023, 8:40:45 PM |
Re: Wirings plugin If you are on Windows: Go to "C:\[USER]\eTeks\Sweet Home 3D" with your file manager. There should be a folder for the plugins. Delete the wirings sh3p file and you can start Sweet Home 3D again. Now first install the Pan3DView plugin before you reinstall the wiring plugin. I suggest that you install the Plugin Manager as mentioned in the post right before yours and use that to install other plugins. On Linux the plugin directory is /home/[USER]/.eteks/sweethome3d/plugins. That is a hidden directory so don't forget to switch your view in the file manager to view hidden files. (Notice the . before 'eteks', hidden files/directories start with a point on Linux.) On Apple? I have no idea. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 23, 2026, 10:36:33 AM |
