Print at Oct 6, 2026, 7:36:05 AM
Posted by johntc at Nov 20, 2023, 5:58:38 PM
Magnetism not working for door model
Hi. Hoping someone can help with a minor problem I have. I've created a custom front door model in Blender and nominally everything works fine, the door renders correctly and hinges all work, however even though I have 'door or window' set when importing, and the model will create the correct cut out in the wall, I can only position it if magnetism is turned off ? Otherwise it will not penetrate the wall. I assume this is an additional setting in the PluginFurnitureCatalog.properties file? I'd rather not go messing with that without knowing what variables need to be added/changed first. On this note, is there a definitive list somewhere on the variables available to furniture objects in this file, I don't seem to be able to find one ?
Thanks for reading and any help would be appreciated.
johntc
