Print at Sep 29, 2026, 5:04:41 AM
Posted by Puybaret at Nov 21, 2023, 10:21:29 AM
Re: Transparency value in color selector
I don't plan to program this feature and even removed the transparency setting in color dialog box. Why? Because when you start to use transparency on many objects, the 3D view doesn't work so well because some kind of z-fighting between transparent surfaces close to each other appears. You surely experienced this behavior when you use existing wall transparency and rotate the home. If it happens more often, this will end by endless bug fix requests.
