Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Side view plug-in » » » » Post: Re: Side view plug-in |
Print at Oct 16, 2026, 5:05:46 AM |
| Posted by Keet at Nov 24, 2023, 9:42:07 AM |
Re: Side view plug-in Use Modify Walls where you can give each side (left/right) of the wall a different color or texture and you can set a color for the top of the wall (no texture). This will show in the 3Dview and photo renderings. Look at the arrows on the wall when it's selected to see what is left and right. You can select multiple walls to give them all a different color at the same time. You can also set a pattern for the top-view of the walls in the 2Dview. This way you can use different patterns for the inside and outside walls. ETA: This is a default feature for walls and is available without the side view plugin. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 16, 2026, 5:05:46 AM |
