Print at Sep 30, 2026, 10:18:48 AM
Posted by GaudiGalopin3324 at Nov 27, 2023, 9:17:22 AM
Re: the white color on the boxes looks different. Can this be fixed?
The program does have this bug. I assign the same color to both boxes (white is the same there and there). If you assign all 6 sides of the box. then they look darker at the initial rendering level than the same box is just completely white. I often need to model openings, for example, and jumpers need to be made with different textures on the sides of the box. And I make the ceiling a whole white box, so it's more convenient. And then the discrepancy between the white surfaces begins, they are different in brightness. For example, I can only make models of cornices entirely white, with an overlay on the wall such a cornice will look too white. This is only readable on video, I use the initial level of quality, with other levels the loading time is unrealistically long, I am satisfied with the initial level, but the difference in white color is very noticeable. It would be good if the program fixed this bug and at least the white color was the same everywhere with a different destination for the box.
