Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Pan tool in 3D and 2D view? » » » » Post: Re: Pan tool in 3D and 2D view? |
Print at Oct 4, 2026, 3:25:39 PM |
| Posted by Daniels118 at Nov 29, 2023, 4:40:25 PM |
Re: Pan tool in 3D and 2D view? Hi NIMAN, the parallel projection mode is a real orthographic projection, so it can be used to get an isometric projection by choosing the proper view angles. Entering more decimals digits works, they are rounded just for display purposes, so you can get exact angles. Tip: you can place a cube somewhere, rotated with the angles required to get an isometric view; then, while having the cube selected, press CTRL+K to quickly align the camera to the cube, this way you can always return to the isometric view without opening the virtual visitor edit window, and it also works in aerial view mode. Drag the cube to the point where you want to center the view and press CTRL+K again to align the camera to that point. You may also save the camera position to quickly return to specific positions. Daniele |
Current timezone is GMT Oct 4, 2026, 3:25:39 PM |
