Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Port SweetHome3DJS on docker » » » » Post: Re: Port SweetHome3DJS on docker |
Print at Sep 23, 2026, 3:16:20 PM |
| Posted by Puybaret at Nov 30, 2023, 6:50:14 PM |
Re: Port SweetHome3DJS on docker So for now do not compile on linux? Just install subversion, ant and nodejs packages, set JAVA_HOME environment var and follow instructions in README.TXT (if you get a "tsc command not found" error, follow also this tip). I just tried again and it worked.It is possible to contibute to developments? What do you have in mind?---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 3:16:20 PM |
