Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Years of Projects hang on MacBookProM1Max after Sonoma 14.1.1 update? » » » » Post: Re: Years of Projects hang on MacBookProM1Max after Sonoma 14.1.1 update? |
Print at Oct 1, 2026, 1:10:20 AM |
| Posted by rolffj at Dec 1, 2023, 3:31:23 PM |
Re: Years of Projects hang on MacBookProM1Max after Sonoma 14.1.1 update? That seemed to work to get the program open with full libraries, thank you. Exception is only a few older project files open without force quit, yet I can recreate the few still needed later. The only one in Recovery folder still hangs but OK for now. Also the "com.eteks.sweethome3d" portion was not in the path, instead going directly from /Containers to SweetHome3D/ Do I empty the moved Recovery folder and place it back where it was in case ever needed again, or just leave it where I moved it earlier in that path as I have done that worked? Thank you very much for the patient and thorough assistance. You've created a wonderful program that is appreciated! Merci |
Current timezone is GMT Oct 1, 2026, 1:10:20 AM |
