Print at Oct 7, 2026, 10:49:43 PM
Posted by madtheos at Dec 8, 2023, 10:25:45 AM
Re: Dimensions bug and snapping
"on purpose"
What is that purpose?
The error is up to 5cm if I zoom out. That is not trivial. And even with 5mm error, if you have twenty short segments and you dimension one and multiply by twenty, you end up building skewed walls 10cm off.
It is understandable that there is no millimeter precision. 0.5cm being the smallest unit is perfectly fine by me. But when I ask for the length of a wall, I want the length of the wall accurate to 0.5cm, consistently. Not 390cm, 394cm, and 393.5cm depending on the weather.
