Print at Oct 4, 2026, 7:08:45 PM
Posted by sjb007 at Dec 8, 2023, 5:36:28 PM
Re: Pan tool in 3D and 2D view?
Hi Daniels118,
I'm having a minor issue with the Pan3D plugin where I cannot open the Pan 3D View Settings dialog. It simply fails to do anything. I still have your autologger installed, and it prints a nice big exception in there which I will post below.
System deets:
Ubuntu 22.04, On Intel CPU/iGPU
SweetHome3D 7.2 and Pan 3D 4.0
I tried moving pan3dview.xml to another filename, and I still get the same exception.
DynamicPluginLoader: plugin.classpath property not set
SPI for freehep PNGEncoder installed!
Object3DBranchFactory replaced with ExtensibleObject3DFactory
DimensionLineEx3DFactory added successfully
Line width changed successfully
Wiring3DFactory added successfully
View3DEnhancer installed successfully!
Exception in thread "AWT-EventQueue-0" java.lang.ClassCastException: java.lang.Float cannot be cast to java.lang.Double
at java.lang.Double.compareTo(Double.java:49)
at javax.swing.SpinnerNumberModel.incrValue(SpinnerNumberModel.java:349)
at javax.swing.SpinnerNumberModel.getPreviousValue(SpinnerNumberModel.java:388)
at javax.swing.plaf.basic.BasicSpinnerUI.updateEnabledState(BasicSpinnerUI.java:501)
at javax.swing.plaf.basic.BasicSpinnerUI.updateEnabledState(BasicSpinnerUI.java:481)
at javax.swing.plaf.basic.BasicSpinnerUI.access$200(BasicSpinnerUI.java:50)
at javax.swing.plaf.basic.BasicSpinnerUI$Handler.stateChanged(BasicSpinnerUI.java:1057)
at javax.swing.JSpinner.fireStateChanged(JSpinner.java:458)
at javax.swing.JSpinner$ModelListener.stateChanged(JSpinner.java:386)
at javax.swing.AbstractSpinnerModel.fireStateChanged(AbstractSpinnerModel.java:119)
at javax.swing.SpinnerNumberModel.setValue(SpinnerNumberModel.java:447)
at javax.swing.JSpinner.setValue(JSpinner.java:354)
at it.ld.sh3dplugins.pan3dview.ui.SettingsTab.createComponents(SettingsTab.java:176)
at it.ld.sh3dplugins.pan3dview.ui.SettingsTab.<init>(SettingsTab.java:83)
at it.ld.sh3dplugins.pan3dview.SettingsController.getView(SettingsController.java:53)
at it.ld.sh3dplugins.pan3dview.ui.Pan3dViewPanel.initComponents(Pan3dViewPanel.java:66)
at it.ld.sh3dplugins.pan3dview.ui.Pan3dViewPanel.<init>(Pan3dViewPanel.java:60)
at it.ld.sh3dplugins.pan3dview.SettingsAction.execute(SettingsAction.java:50)
at it.ld.sh3d.devtoolkit.DynamicAction.execute(DynamicAction.java:62)
at com.eteks.sweethome3d.swing.HomePane$ActionAdapter.actionPerformed(Unknown Source)
at com.eteks.sweethome3d.swing.ResourceAction$AbstractDecoratedAction.actionPerformed(Unknown Source)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:842)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:886)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:289)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
X11Util.Display: Shutdown (JVM shutdown: true, open (no close attempt): 2/2, reusable (open, marked uncloseable): 0, pending (open in creation order): 2)
X11Util: Open X11 Display Connections: 2
X11Util: Open[0]: NamedX11Display[:1, 0x7f749c02ad20, refCount 1, unCloseable false]
X11Util: Open[1]: NamedX11Display[:1, 0x7f74e0001de0, refCount 1, unCloseable false]
