Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Process for orthographic, outlined, sectioned, images. » » » » Post: Re: Process for orthographic, outlined, sectioned, images. |
Print at Oct 4, 2026, 8:16:39 PM |
| Posted by NIMAN at Dec 11, 2023, 3:18:16 PM |
Re: Process for orthographic, outlined, sectioned, images. There's only an option which allows to draw the contour of each polygon drawn by the program and this option can be activated in Pan3DView plug-in, but this option will show many undesired lines in a side view as shown in the following image. The undesired lines seem to be of little/no consequence in the use case envisioned, which is: Import of SH3D Display side view plugin png image (which includes polygon contour and at as high a resolution as possible) to Inkscape as a basis for tracing sectional vertical elevations therein. However, from what I can tell so far, SH3D side view plugin window output is different based solely on Operating System (Win7/Win10). On Win 7 this image, seems to, show the polygon contour in the Display side view plugin window: https://postimg.cc/hhhkfJYC But is not present in the Win 10 equivalent. Again, from what I know, both Win 7 and Win 10 SH3D setups are identical and pan3d view settings, relating to the screenshot image, on both are "Outline/parallel projection". For the use case it'd be nice to have the side view window also have the polygon contours in Win 10. |
Current timezone is GMT Oct 4, 2026, 8:16:39 PM |
