Print at Oct 4, 2026, 3:18:29 PM
Posted by mts749 at Dec 20, 2023, 2:00:01 PM
Re: Multiple levels displayed regardless of their elevation.
Thanks for the quick response.
I assumed that it worked the way you describe but this has not been my experience. Some elements (furniture, rooms, walls, etc.) of the lower layers do not show up in some of the upper layers. I have a layer called "All" whose elevation is above all the others but not everything shows up. Note that none of my rooms (not in the SweetHome sense but in the building sense) overlap one another, they are just at different elevations. They are all adjacent.
I would like to attach some images to illustrate the problem but I have tried and can't figure out the proper syntax and url. I'm using OSX. Any advice on this would be appreciated so I can better show the issue I'm having.
Many thanks.
