Print at Sep 23, 2026, 1:52:05 PM
Posted by Daniels118 at Dec 22, 2023, 2:53:49 PM
Re: 3D rendering using GPU cores
I can give a little anticipation: the solution I'm working on will be cloud based, that means that you won't need to buy costly hardware to speed up your renderings. But, even more worthly, you can continue working on your home, or just power off your PC while the rendering is executed in the cloud. And, moreover, you will be able to render files made with SweetHome 3D Online, without the need to install the program on your PC.
